I have a 6.0 in the shop that appears to have had every injector go down at once.
Ohm tested one injector and it shows 0 on the ohm tester like a straight short on both coils.
Ficm tests out perfect
Icp is good,
Sync is good
Buzz test refuses to do anything
Throws code on every cylinder for injector circuit low
Any idea as to why every injector went down at one time. For what it's worth the truck blew the egg cooler when it was shut down last time it was driven. Once it was shut off it never fired again.
Icp is good,
Sync is good
