powerjoke4life
- Joined
- Dec 27, 2011
- Messages
- 731
- Reaction score
- 0
Hey guys Im new to 6.0 so take it easy on me if I ask silly questions.
03 6.0 studded and deleted, It will start about half the time, and half the time it will not even crank. Pulled codes and it says its failing pre-check but won't tell me what is failing. I has a couple other codes, cylinders 1 and 3 have a code that says something like its not getting fuel, blanking on what exactly is says right now. And KAM code. So once it starts it idles rough, and when you drive it the truck will only go about 50mph tops floored. I put it on the trailer last night and would barely drive up the trailer Pic for your fun.
I have a list of things to check but if you guys have any more suggestions that would be helpful.
Things to check, EBP, ICP, FICM, IPR, MAP, Fan Clutch sensor. Anything else?
[/URL][/IMG]
