As the post says what is needed to do this? I had three lifters go bad. None are really bad just one that has a little flat spot and when you shake them you can hear the roller moving up and down. Cam looks great which is a plus. I'm just trying to get parts together to do lifters. I have ordered new head gaskets and studs. a full egr ******. updated stc fitting. I have new injector o rings and intake seals. my valve covers are only a year old with less than 10,000 miles on them so I'm just going to run them and if they leak ill replace them. So what else do I need?
anyone's input will be great
thanks,
Levi
thanks,
Levi
