Well I got my turbo and ic tube put on and started my truck and there is a knocking/ticking coming from the motor it almost sounds like a gasser exhaust leak. My first thought washpush rods so I took valve covers and oil rails off and the rockers look good how do I check the pushrods without removing them? When the motor is beung turned over it sounds like compression is escaping from somwhere on the drivers head. What else could the noise be? What else should I try checking?
