G Racing
Ok. Got a 06 f250 with a hot no start. Truck has a sct with a tow tune. Other than that pretty much stock. When it's cold it will start like normal and run but has a big lag at take off warm or cold. When it's hot and you go to start it, it spins over just fine and try's to start. It acts as if it doesn't have enough fuel to keep running and will stop running.
It's almost like an old gas engine that wants to run after being turned off. Kind of hard to explain I guess. No smoke while cranking. Everything looks fine. Icp is 700+ while cranking. Ipr is 15-16%. Ficm and battery voltage is good. New fuel pump. Good fuel pressure. Good lpop pressure. No trouble codes. The only thing I get is a PCM fail on a KOEO self test during a hot no start. Replaced the FICM with a known good one. Started fine but would not restart when hot. It's like the injectors won't fire on a hot restart. A little shot of starting fluid and it will start and then run fine. Anyone have one that acted like this?
