Derek@Vision Diesel
Engine was out of the truck for a full delete and head studs.
Put it back in and hooked everything back up, no start. I am seeing 350psi of HPO but it stops right between the 330-350 mark every time i crank. Is it possible i need to keep cranking on it, seems like ive cranked 25 times already.
Fuel pressure is good
all connections are good
replaced stand pipes and dumby pipes about 30 minutes ago with no change.
no way to get the air tool to check for leaks
FICM voltage on the AE is reading good
No idea what could be wrong, any ideas?
