imelmo
- Joined
- May 18, 2011
- Messages
- 6,632
- Reaction score
- 2
Got this off of FaceBook from "Senior Master Technician". He's got a lot of good vids on YouTube also. He's always got a lot of good info:
Would you like to know why the 6.0lit oil cooler fails? Would you like to know the truth? As usual, you only here it hear it first! The root cause of the oil cooler restrictions is caused my metal slag left over from the casting of the engine. This is why the VC-9 iron cleaner is required to help dissolve the particles in the engine block. Then by removing the the engine block plugs with the water hooked into the system allows those heavy particles escape from the cooling system. Video highlight uploading here now!
