6.0 power steering question!!
Strudwick32
[/ATTACH] this is my high pressure line on my steering pump. It's real tight but not sure k all the way. I'm worried the o ring will blow back out. Any suggestions? And it went in easy so it's not cross threade. Second question. Since my breaks and power steering went out I had to put fluid in the tank twice but my reservoir stayed full. It never feed the tank. Is this because the leak? Or is there another proble.?
Mesa, AZ
That look like its in all the way. Now what do you mean had to fill the tank twive, but yhe reservoir was full?
Strudwick32
The tank went low twice because of the leak on the high pressure line. I had to refill it again because it never took any from the reservoir
Zmann
if it leaks you would expect the reservoir to run low ?
is this a new HP line or new leak on an old line or ???
if new what brand ?
