powerlifter405
Truck:
2005 6.0 289k miles runs GREAT when warmed up. Starts up fine cold no smoke, slight stutter when cold only on acceleration.
Original HG, turbo and exhaust. Recent EGR deleted, rest all factory, NO tuner, ever.
2 injectors were replaced at approx 187k.
Intake was "carboned up" per Ford, EGR cooler and intake were placed approx 187k. Oil cooler was replaced at the time as well. No notes about oil cooler issues/back pressure/ or HG. I have every ford receipt/work order from the original owner. I am owner #2 acquired as a theft recovery.
Problem:
Bed plate or rear main is leaking. Slight stiction when cold. The turbo seal is leaking( i rerouted the CCV and tested things w/ the CAC off and oil is weeping out of the mouth of the turbo.)
I am contemplating doing a basic gasket refresh. I want reliablility nothing more really, unless I get some bonus mpg then even better.
I saw that strictly diesel has RCD HG supposedly the same as ford but I find little on their success. I am pricing out and making a list of things to perform. Here is my list if I can get some ideas if this is the right direction.
From what I'm finding on PSA and a few other sites:
Heads, no more than 0.007
Valve job, move the valves up .010, valve recession to roughly 0.018-0.020 on the intake 0.025 on exhaust. roughly 0.010 off the stem top of the valve
To compensate for the valve job.
3C3Z-6020-CA -------- Engine Timing Cover Gasket
3C3Z-6700-BA ------- front Crankshaft Seal
3C3Z-6701-B --------- Rear crankseal
3C3Z-6D083-AA ---- Rear crankseal flang cover gasket
8C3Z-6565-B ---- push rod ---New length???
8C3Z-12K073A- -------Camshaft Position Sensor
3C3Z-6C315-AA ----- Crankshaft Position sensor
ZC-31-A -------------Block metal prep for HG's
3C3Z-6710-CA ------- UPPER Engine Oil Pan Gasket
3C3Z-6710-BA------- lower Oil pan gasket
Bed plate gasket
Lifters ( OEM or sealed power?) SP is 9.89 @ advanced auto.
Head gaskets (RCD or OEM)
ALL Oil o-rings
STC fittings
Dummy plugs
Stand plugs
Rocker box gaskets
New ford Injectors
MTW stage 1 or maybe 2.
Vivian tunes
I have a shop that has experience in 6.0 heads and will pressure test, magnaflux and mill for $200 total. Fully rebuilt, both head are approx $1,100 referencing the last 6.0 rebuild set. He can put in hardened seats as well.
I'll pull the motor as I dont have a lift. I want a smooth DD
Thoughts and/or ideas? Should I just stud and leave alone? I'd like to do this once and be done w/ it. I've already done the math, at the pricing of the above including injectors and turbo, it's still cheaper than a 5.9 swap w/o any custom install headaches so that is already out of the question.
Thanks:ford:
Problem:
Bed plate gasket
ALL Oil o-rings
STC fittings
Dummy plugs
Stand plugs
Rocker box gaskets
New ford Injectors
Vivian tunes
Thanks:ford:
