C'roy78stroker
Truck is a friends that i came in on the tail end of the repair. Its an 04.5 with 244k miles. Truck was previously stock. Put on Headstuds, Reg Return, DIY 175/75's, 68mm VGT and remaned heads. He started the truck last night and it had a slight exhaust leak. Checked the monitor and ICP was 1100 with 34%DC. FICM is showing 49 volts. I go over to his house today to hear it in person and it was a rough idle that sounded like it had a fuel knock, ICP was 1100 but the duty cycle was 94% with idle speed around 450rpm. Truck will not rev at all, checked the monitor and it shows the ECU seeing full sweep of the pedal. Fuel supply is steady 60 psi. I am thoroughly familiar with the 7.3's and 6.4's but next to no experience with these 6.0's. Any and all help would be appreciated. i am willing to check suggested points with the feedback if that will help these process. Thanks for looking :toast:
