I had a guy bring me a 2004 6.0 with just over 100k miles and a no start/ run issue.. It did have some codes, the most significant being 5 or 6 cylinders with a injector circuit low codes and one with a balance/ contribution fault. I had just put a ficm on this truck 2 months ago, so i pulled the ficm loose and checked the 3 connectors just to make sure one didnt come loose. Also all injector/ harness connections were good. FICM voltage is good, battery voltage is good, ICP comes up to 500psi when cranking, it has fuel at the fuel bowl, fuel filter is good.... Every once an awhile it will fire on a cylinder or 2 but it wont start. I am stumped, any suggestions?
