SaNnDnSurF
Truck leaks oil right under the turbo you can see a small puddle, replaced turbo drain o-ring and still leaking the mechanic I use works at ford is acting like he's stumped only leaks down the back of the motor while the truck is running and for a couple mins after it shuts off any suggestions here? 05 6.0 110k miles
