superstroker1216
- Joined
- Apr 10, 2013
- Messages
- 3
- Reaction score
- 0
Do the 6.0 and the 6.4 use the same tuning strategy to control the vgt? Obviously differences for the compounds, but do they check for similar readings to control vgt position or is the 6.4 closer to the dmax? Just curious because everyone says the way the 6.0 controls the vgt that a vgt can not be used in a compound set up because of back pressure. However I see Dustin is running an elite vgt on his 6.4 fed by an 83mm. Just curious as to why this set up works on a 6.4. And work it does, 900hp is impressive no doubt! Input?
