GreasyFingers
- Joined
- Sep 13, 2011
- Messages
- 627
- Reaction score
- 0
A good friend of mine (Tim) has been needing my help with his '03 6.0. He is a retired disabled Vet and can no longer do this kind of work himself. He bought the truck (his first diesel) about 4 moths ago from a dealer. Supposedly the salesman was telling him about what a great truck the 6.0 is and wont have the troubles that are notorious to the 6.4's! What a scumbag! So Tim was wanting a cooling system flushed because it looked nasty. He took it to a shop and they said they would charge $250 and it will be done in 30 minutes. Tim didn't want a 30 min. half ass job so he asked me if I could do it, he knows I get a little OCD with my truck and knew I would do it right.
I really don't know too much about 6.0's and this is a good learning experience and I get to help a true friend in need. I did the flush and filled the system with distilled water while I checked for other issues, and boy did I find them!
First his Radiator is leaking around the top tank, water is leaking from the EGR cooler, I pulled the EGR valve and it is wet in the manifold but no smoke from the exhaust, and the oil coolant delta is 26* peak on a fairly flat road. I informed him of what I found and he wants me to get it fixed right.
He is on budget so I've been shopping around for decent prices. here's my plan;
OEM Ford oil cooler w/gasket kit
EGR delete w/up pipe
intake gasket set
IPR's stainless HPOP screen
hot tank the intake manifold
coolant filter
BPD radiator
CAC boots
CCV w/oil separator to the exhaust
Here are my concerns; will the delete set a CEL on an 03? If so, I will likely go with a BPD cooler. Tim says he has no intentions on getting a tuner and he is older and can get a little confused so I want to keep things simple.
I've read that removing the EGR valve can negatively alter some parameters.
I seen several people install a new oil cooler only to have it clog in a few thousand miles. Is there a alternative to the stock oil cooler besides BPD's which is cost prohibitive?
What else should be done while I am at it?
I am looking for the best prices on quality parts so if any vendors have any specials please let me know.
Thanks
Rick
intake gasket set
coolant filter
BPD radiator
CAC boots
Thanks
Rick
