6.0l rod torque
reilly8282
Just like the title says. Anyone help me out with rod cap torque? Cant seem to find that spec using search. Thanks in advance.
reilly8282
Awesome. Thanks I have looked there but must have missed it. Turns out the pistons weren't burnt they just had some carbon muck on them from I guess the gaskets leaking. I had one apart and replaced it but positioned the crank so could clean the other one and the edge was perfect. O well just my luck, the one I pulled you could scrape it with a knife and fine the true unburnt edge just fine. Thanks for your help.
reilly8282
Anyone have an extra small head bolt? One of the small bolts that goes on outside the valve cover, I managed to snap one tonight. Thanks.
