6.4 head studs/ gaskets
JD_MILLS
I need a bit of help in the process of installing arp studs and new head gaskets. when putting the head back on the passenger side the wire off the sensor on the up pipe and the connector wound up in the back cylinder. I didn't catch it until I started putting push rods in and couldn't get the crank to make a full rotation. so I took the nuts back off the studs and raised both heads up a couple inches. got it out and let them slide back down I know i'm going to replace the passenger side hg because it has a line where the wire was between the head and the gasket. but can the driver side still be used?
Dzchey21
wyoming
once the gasket is crushed its done for, get both new... sorry to hear but that kinda stuff happens
