6.4L HP Turbo Components
buckster
Houston, Texas
Inside the high pressure turbo, there are three bolts that thread directly into the center section. They seem to be what the VGT ring slides on. Can anyone advise where I can source new ones?
Powerstroke Cowboy
Montana
If there is markings on the bolts you could always go to a hardware/fastner store and get them matched up.
Or just pick up some stainless bolts that match.
Powerstroke Cowboy
Montana
I think the heads are fairly low profile
They look like it in the picture. A good fastner store should have what's needed.
If not, grind or belt sand the heads down to match.
Another way would be to check with a sponsor on here. Like KC Turbos. They might have something as well.
