7.3 injectors, fuel pump, hubs and more
powerstroke0273
baton rouge
Did a little shop cleaning and have a few parts for sale. Will ship and take paypal as preferred payment.
1. Set of 8 AD fuel injectors with 125,xxx on them out of 02 f250 . will include a full set of new O-rings for them.
2. Ford auto lock hub 1C3Z-3B396-CB. One is new in box other is used.
3. Rear drive shaft flange @ transfer case F81Z-4865-CA- new
4. Ford fuel bowl o-ring set F81Z-9C065-AA-new
5. Airtex fuel pump E2236-new
6. Set of fog lights off an 02 f250 used
7. 2 rear lariat door panels with window switch , crew cab used
8. Rear sway bar links-new
9. Front outer axle seal, National seal 710493 ( for front axle )-new
10. Dorman ABS sensor for rear axle-new
11. 28 Gorilla spline lock lug nuts w/ key 14mmx2.0 ( for corse thread studs )-new
12. Seat belts- complete set for rear crew cab, driver front & jump seat belt and buckle - used
13. Front factory shock mounts- used
Make offer,Thanks
powerstroke0273
baton rouge
Update- fog lights sold
1. Set of 7 AD and 1 AE fuel injectors with 125,xxx on them out of 02 f250 w/ new orings installed. Asking 650 OBO
2. Ford auto lock hub 1C3Z-3B396-CB. One is new in box other is used. Asking 125 on the new one and 80 on the used -OBO
3. Rear drive shaft flange @ transfer case F81Z-4865-CA- new - Asking 65 obo
4. Ford fuel bowl o-ring set F81Z-9C065-AA-new asking 25 obo
5. Airtex fuel pump E2236-new- Asking 80 obo
6. Set of fog lights off an 02 f250 used- sold
7. 2 rear lariat door panels with window switch , crew cab used - asking 225 obo
8. Rear sway bar links-new - asking 40 obo
9. Front outer axle seal, National seal 710493 ( for front axle )-new - 40 obo
10. Dorman ABS sensor for rear axle-new - 10 obo
11. 28 Gorilla spline lock lug nuts w/ key 14mmx2.0 ( for corse thread studs )-new - 45 obo
12. Seat belts- complete set for rear crew cab, driver front & jump seat belt and buckle - used - 175 obo
13. Front factory shock mounts- used - 50 obo
powerstroke0273
baton rouge
Update-
1. Set of 7 AD and 1 AE fuel injectors with 125,xxx on them out of 02 f250 w/ new orings installed. Asking 550 OBO
2. Ford auto lock hub 1C3Z-3B396-CB. One is new in box other is used. Asking 125 on the new one and 80 on the used -OBO -NEW ONE SOLD
6. Set of fog lights off an 02 f250 used- SOLD
7. 2 rear lariat door panels with window switch , crew cab used - asking 175 obo
12. Seat belts- complete set for rear crew cab, driver front & jump seat belt and buckle - used - 175 obo - SOLD
13. Front factory shock mounts- used - 50 obo - SOLD
