This is a customers truck, havent really dug into it yet, but am looking for some input. Seen it a lot on 6.0s, but not really 7.3s.
Trucks a 2000-01Ex has about 88k on it. Has a banks power pack with the wastegate, gauges, exhaust, and im guessing tuner. Came in dropping dash pressure at rpm, typically dropping out around 2500-3000. Found oil very thin, and had some aeration. Customer said only had about 1500 mi, but unknown time and was guessing on mileage. I changed the oil and filter real quick before going home. On start up it drained the rervoir, then stalled, and had to crank the hell outta it to start it. After the oil change, it still drops dash pressure at approximately same rpm. If its held on the limiter for about 30 sec, it runs rough on return to idle for about 5 sec then smooths out.
I have not checked base pressure yet, but will a hi pressure issue cause this? I am thinking something with the base pump like something went through it, like a 6.0, but with the low mikes, im not sure.
Thanks and sorry for the long post. :toast:
