7.3 LPOP Problem
Gary
South Lyon Mi
I have a 7.3 that doesn’t have any LPOP. It was going down the road and quit.
I checked the oil reservoir and it was low, so I filled it up and the engine ran for about 15 seconds then quit. I check the reservoir and it’s empty again. I pulled the LPOP pump apart and everything looks perfect, so this engine is dumping the oil pressure internally.
Anybody ever come across this problem before? Could it be the pressure relief in the oil cooler? Somebody did tell me there is a plug the blows out somewhere towards the back of the block and that could be where the oil pressure is going.
Anybody has a flow chart of oil pressure? Sometimes the factory manuals would show that.
All these years of working on 7.3’s and I’ve never seen this problem before. Also this van only has about 130k miles on it.
DEEZUZ
NO PUKESTERS
NWI
What year is the engine? 95s had a airetion valve that falls out of the front cover and causes no lpo.
All other ones has the regulator in the oil cooler housing fail. You can try to take it apart to clean it, polish it. But I've always bought a new oil cooler end cap/oil filter housing.
Mesa, AZ
Does it have oil in it? At 6-7 quarts they quit running, could just be low on oil.
Gary
South Lyon Mi
It’s full of oil. Even looks clean… lol
I’ve done plenty of 7.3’s over the years and I’ve never seen this problem.
Mesa, AZ
Try draining the oil and using a borescope to try and inspect the pickup tube. Could be plugged full of shit.
DEEZUZ
NO PUKESTERS
NWI
Only 2 I've evr had with no lpo were the valve in front cover in early ones and the regulator in the filter housing.
DEEZUZ
NO PUKESTERS
NWI
I took the housing down and regulator apart and didn't like the feel of it. I don't recall if it was that scored up, but I replaced it and had lpo and truck fired up.
Gary
South Lyon Mi
This video shows a plug for the oil galley that is on the rear of the engine. This could very well be the problem, it would fit for the story that i was told about how it quit.
dunerunner52
I had an injector o-ring go bad - it would push oil back into the fuel system. Suck the oil level down real quick and as you know, the LPOP starves.
patsmobilepmcs
florida
ok what year truck do you have ?
Gary
South Lyon Mi
Thought I would give an update on this 7.3.
I pulled the engine and took the back cover off hoping it find a plug out. Nothing, both plugs were there just like they should be.
So then I pulled the oil pan and front cover. I didn’t find anything in the pan and don’t see anything wrong with the cover.
Any other suggestions?
Powerstroke Cowboy
Montana
Do you have a picture of the front cover where the oil pump sits? I lost oil pressure due to wear on the front cover.
That gasket doesn't look to good. Haed to say if it wasn't sealing though by that picture.
How's the oil pickup tube look? They have been known to crack.
As mentioned above, have you checked or replaced the oil pressure regulator?
Gary
South Lyon Mi
I forgot to look at the oil pressure regulator, I already have the cooler off the engine.
I’ll check it and see what it looks like.
The story I got was they were driving down the road and it just quit.
Gary
South Lyon Mi
I looked at the pressure relief in the oil cooler and I did see a little chunk of something, look at the picture, I don’t think that was the problem.
The pressure relief has spring tension and feels good.
There is a video on YouTube that shows if you see a gap between the teeth on the oil pump it’s no good. Well I do see a gap, so maybe between the pickup oring and the pump that caused the oil pressure loss.
I’m getting in contact with previous owner to clarify exactly how it broke down.
