7.3 parts
1ofakind79
Herminie PA
All parts are located near Pittsburgh PA at 15089 zip. Will ship small stuff. All prices are + shipping.
7.3 Forged long block. 180K on it. Will consider parting out if there is interest.
$400
oil cooler $50
Intake Y for intercooler. $30
SD inframe fuel pump with bracket. $50
Intake plentums 2" $25pr
17 degree hpop marked as reman. I've never tested it. As is. $125
drivers exhaust manifold $25
pass exhaust manifold $25
up pipes & turbo Y $40
98 444E wiring harness with UVCH $25
crankcase vent $25
Injectors AB code. All are marked as remans. I've never tested them. PO said truck ran fine. $400 for all
Turbo off 444E. non wastegate no warmup valve. some shaft play. $125
1ofakind79
Herminie PA
They are all from a 98 international 444E. The heads, hpop, and injectors are the same as a pickup. The exhaust manifolds and Y are different from a super duty. I'm not sure if they are the same as an OBS.
