7.3L SUPERDUTY Fuel Pump Kit
POWER-STRUCK
Indiana
stock replacement fuel pump kit that has necessary parts and hardware needed to replace the pump and to install an inline pre-pump filter allowing the user to remove the in-tank screens.
works great for trucks with sediment in the tank or a metal tank that is deteriorating (common problem found on chassis cab)
the filter is see thru, sediment can be seen visually and can be changed in seconds. the replacement filter is inexpensive and readily available at most parts stores.
current price is $125 shipped
