99 7.3 crank but no start
NateMiller
I have a early 1999 powerstroke its got a 75 hp tuner 4" turbo back exhaust and a k&n air filter. I recently got new injectors glow plugs and valve cover gaskets. then right after I got those my*hpop*went out so I got a new one. Drove it for about a week and now it wont start. Right before it stopped running it was running very ruff and didnt like to start. Now it wont start at all. The oil level is full and is getting oil to the*hpop*and getting fuel to the fuel bowl. I just replaced the fuel filter also. I tried just a little bit of ether and wont even pop off. Checked the codes and only p0603 powertrain module code came up but I think its from unhooking my batteries because it came on right after. Let me know what yall think. Thanks, Nate
Magnum PD
VA
Haha. At the front of the engine, the very bottom pulley is the harmonic balancer. It mounts on the crankshaft. Look for a wire that hooks up to a sensor. You will see a 10 mm bolt holding in the sensor. With me?
