ABS light on, No response from module
Vader's Fury
Chesapeake City, MD
Got a 2005 f-450 that I recently bought and am trying to get everything on it working right. I currently have an ABS light on, but when I try to connect with my A/E I get no response from module.
I tried to connect directly to the abs system and it is saying not supported/not found.
I swapped the control portion of the ABS module out but no change.
All fuses and relays are checking out.
Everything else on the truck seems to work fine, only having an issue with ABS light on.
powerlifter405
Butt Town
Could be a wiring issue. When I installed new ford hubs, originals had 295k, the passenger side set of the ABS light. It ended up being a break inside the new wiring harness.
