truck is an 03. under normal braking, coming to a stop smooth and slow, just before you are at a complete stop you can feel the abs pump in the peddle and the steering wheel has a slight jerk to the right. this only does it before you are at a complete stop. all other braking is normal. there are no ABS fault codes.
could the tone ring be dirty. or a bad wheel speed sensor be to blame?
