Adding cab lights
Bigcountry250
Where is the best place to get a factory cab light kit?
Is there a place in the truck that it would plug in or would it have to be wired to a separate switch?
WHY NOT
Carlyle IL
There is a factory plug that the harness will go into, but mine already had a plug in it so I just ran the wire where it needed to go. You can go to the dealer to get the lights and harness or ebay. I put recon's on my truck they are still working, knock on wood, but if I did it again I think I would go with the factory ones.
Bigcountry250
I don't want the dealer to install them, a buddy of mine has done a bunch and is good at it. I just want to buy them from the dealer.
bad12jr
Recons track record could be a lot better. I'd get factory lights and put smoked or clear afrermarket lenses if that's what your after.
Sent from my x2 chillin in the middle of no where
uga33
Cartersville, GA
One thing to note. The 08+ trucks plug in on the drivers side under and behind the e-brake. Older trucks plug in on the passenger side behind the kick panel somewhere.
