air dog 2 and elite fuel bowl delete install questions
krasselt21
I am in the process if adding an airdog 2 165 and elite fuel bowl delete with dual fuelers. questions are with the return lines. the airdog goes into the filler neck so does the fuel bowl delete go in the factory location? any picture of each install wouls be great also.
08BIGRIG
WI
The fuel bowl delete does go into the factory position.
Sent from my iPhone
-Jerry Bruley-
08BIGRIG
WI
Are you asking where the return line goes to from the fuel bowl delete? Please clarify what you are asking a little.
Sent from my iPhone
-Jerry Bruley-
Nick284
Buffalo NY
im in the same boat but looking for the right answer and a little diffrent set up. going dual pumps, no bowl ****** block. im just using a T fitting for feed and return. so i run my feed line to my pumps, now for my return line! from my pumps, the return line goes into the tank correct? now for the other "port" on my AD pump. i just run a line from that to my filler neck?
West Virginia
If you contact airdog, they did a revision to the 6.4 kit. They can send a return tee with the quick connect ends and a different hose. Had the same trouble with my kit couple years ago
Sent from my XT1093 using Tapatalk
