Air dog install help!!!
6fodays
va
Looking for someone that has installed an air dog 2 165, how in the hell can these 2 fitting fit side by side? You cant even fit them close to their holes.
6fodays
va
Welp never mind, broke the fitting. Ruined the air dog. Anyone know if you can just buy the filter base by itself, without the pump and all?
capt dong
Houston, TX
I forgot which one but one goes in before the other and theyll fit. Call up pureflow. Theyll sell you another base.
78f100
Bonifay FL
If you can get that out you can re tap the hole. Iirc you have to put the big fitting in first there is a sweet spot where the shoulders will clear each other.
6fodays
va
Was gonna retap but it expanded the whole hole
Oil Field Trash
Jonesville MI.
Im pretty sure the instructions tell you which fitting is inserted first, and where to clock it so the other one clears it...
They make tools to remove the broken chunk. Then i would chase the threads with the same size tap to clean it up. i would not make it any larger. you may have a serious issue finding fittings that will clear each other if you go to a larger size.
6fodays
va
I ordered another base and fitting for $85
Jbird
Helicoil wouldve cost ya about ten bucks and few minutes of your time
