Lassie
I've had two issues with my truck over the years that had to do with missing or rough idle...Both started after alternator issues. The first time, years ago, my battery light had come on a week or so earlier. The batts checked good, so I kept driving. When the alternator finally stopped charging, the truck bucked and jerked badly and shut down. I replaced the alternator on the side of the road and the truck started with a terrible miss....Ended up with #4 and #6 contribution/balance codes. I changed the driver side bank of injectors and cured the miss.
This month, i was on an out of state hunting trip, and the battery light came on again. I was able to monitor with autoenginuity and the batteries were holding but alternator not charging. I didn't make it off the hunting property before the bucking started and I shut her down. Had a family member bring an alternator and jump me. Truck started and ran perfect for one minute....then the idle got rough and I've had a cyl cont/balance code on #1 ever since.
I've read alot about low voltage killing FICMs, but in neither of these cases have I had FICM problems. I did have to resolder my FICM board in the past due to a code and low voltage, but not near an alternator/battery problem.
Maybe it's just a coincidence, but it seems to me loosing an alt kills injectors. Just wondering if anyone else lost injectors due to batt/alternator issues?
