Bane456.4
Anybody running Amsoil in a 6.4? Can you tell the difference?
Did it stop leaking after changing oil?
nope had to pull the motor and re seal the bed plate on both 6.0 and 6.4. running delo now 50k mi with no oil leak issues.
I run amsoil and mine leaks too. It hasn't leaked enough for me to pull the motor but I can see it when I go under the truck. Thinking about upgrading to a frame mounted oil filter kit.
Is it wet around where the trans meets the block and running down on the oil pan bolts?
more than likely bed plate is leaking. Trans has to come off for sure and maybe just be better off to pull the motor. Lucky you, I had to do it twice. Lol
I run it exclusively year round in my 2010 6.4 with 54K and my dads 2002 7.3 with 345K and brothers 2000 7.3 with 275K in the central texas heat.
Maybe we got the good batch. But seriously, Amsoil = seal failures??? Good luck with that.
We recently flushed my dads transmission and added amsoil to that as well as his front and rear diffs.
I'm not there on my truck just yet.
im not saying thats what caused it, but just kinda funny both my trucks leaked in the same spot. different engines too. on my 6.0 i fixed the leak and still ran amsoil. swapped out all my fluids for amsoil only because my work was a dealer for them. truck ran with no leaks till i sold it, so who knows now. on my 6.4 i fixed the leak and now run delo because im a cheap ass. :thumbsup:
