ghohouston
Yesterday I installed a new front cover gasket on a buddies 6.0 due to leaking coolant. This is not my first front cover gasket, ive done 10-15, but its been about 2 years or longer, anyhow, when I pulled the lpop, it slid right out like normal and like all other trucks ive worked on. When I went to re install the lpop, I COULD NOT get it back in, and once again, ive done quite a few 6.0 lpops due to lifter failure and front cover gaskets, so I know they dont just immediately slide right in, but this was different. I lubed it up heavily with oil like always, etc, and it would not slide in no matter what i did. Buddy said, just try tapping on it with a hammer, and it being his truck and money, I went along with it. I didnt have to hit it hard or anything, but it just didnt sit well with me, going against what I knew was wrong. Anyhow, the truck is running now just fine, and leak free. Has anyone else had issues like this? Fyi, I did verify all front cover bolts were on good and tight and the cover was flush, and before anyone asks, no I did not put the wear sleeve on before I tried to install the lpop.
