BigRedDiesel
I just got mine back from being rebuilt and one of the hold down brackets is on backwards. Is this something I can do myself or do you need special tools for this? I really need to get this truck running ASAP!
Who did it ? Not something you can fix your self without the proper tools.
My apologies. I jumped the gun. The solenoid was on backwards not the bracket. Looked closer and found the oil discharge was in the right spot just not the plug...
Maryland fuel injection
So MFI put the hold down on backwards? Or Farmer's?
MFI put the solenoid on backwards.
At least that is my understanding...
It was the solenoid not the bracket. I went to install it with the plug facing the center of the engine noticed the bracket was backwards. I posted in a panic because I had to get the truck running. Went back out to look and the oil discharge port was in the right spot in relation to the bracket then realized it was the solenoid that was flipped around.So MFI put the hold down on backwards? Or Farmer's?
Correct...MFI put the solenoid on backwards.
Either way...MFI put the solenoid on backwards.
I agree with this!!^^^^Not a good way to start your injector building service out lol.
This was also a less than 24 hour turn around and on our Machine you can run them if they are backward and not notice it....mistakes happen all that matters is his truck is up and running and fixed
Sent from my SAMSUNG-SM-N900A using Tapatalk
