anyone have issues with turn signal?
sleeps
Virginia Beach, Virginia
Used to work fine. Then slowly started to work less and less often, but would work. Now it doesn't work at all. Does the switch itself that attaches to the steering column go bad often?
co04cobra
WV
Yea they do fail fairly often. Are you getting a fast flash? or annoying buzzzing sound with the signal on? Does it do it both directions?
20007.3L
Manchester, NH
They come out easy, 2 torx believe if i remember correctly and PM me for a price!
Hey , it is 2 torx right?
co04cobra
WV
You got it. 2 T-20 torx I believe, and 2 plugs. Well you do have to remove the steering column covers. 3 phillips screws and the tilt lever.
