Auto enginu
jdeeg4276
Vancouver wa
Got a question. Is there a way to read the HPOP from this program. I'm might be pressing all the wring buttons. And watching all the wrong readings. Thanks.
jdeeg4276
Vancouver wa
A picture at idle.
Mdub707
Mohawk NY
You want to watch ICP actual and ICP desired. Desired is what the PCM is requesting, and actual is what the HPOP is putting out. You have 577 for actual there and 580 for desired. Your IPR % will increase with throttle input and both of the ICP numbers should increase. They should stay pretty much the same throughout. They will constantly be fighting back and forth, but should remain really close. At WOT, they should go up towards 4000psi.
