Axle comparison 08-10 F450 vs 11-14 F450
Santa Fe NM
Recently purchased an 08 F450 4x4 with 4.88s and its a little more gear than I need. I found some axles with 4.10s from a 12 F450 and was wondering if I could either swap out the gears or axles to run the 4.10s. The axles are way cheaper than swapping out for a new set of gears and that's the only reason Id consider swapping. Thanks for any advice.
Strokersace
Towanda, KS
The 11+ rear axle doesn’t have the speed sensor like the 10 and earlier trucks do. So don’t know if it’s be a direct swap for you. However, you could swap gear sets between the axles.
rescuejg
Also the 08-10 450s are 10 lug with the Dana 110 in the rear and the 11-14 are 8 lug with a Dana 80 rear. The 15 and 16s went back to 10 lug.
If this is correct then i believe @Strokersace would be incorrect about being able to swap gears front and rear. Front would still be a yes since they are both Dana 60, but it sounds like the rears are different.
Sent from my SM-G973U using Tapatalk
Powerstroke Cowboy
Montana
Three year old thread my friend.
But yes, you are right, the rear axles are different. I think the front is to. Being the 08-10 f450 used a beefed up 60. Yes ots also the wide track, but it's also built bigger.
