Axles
DZL JIM
North East Ohio
$100 - OBS rear axle, 10.25 dually, full width, not cab & chassis, hub to hub, both spring packs available with this axle.
$300 - '01 Super duty front hub to hub, $300
$300 - '01 Super Duty rear hub to hub, $300
Not sure on gear ratios, all came from wrecked trucks.
Located in North East Ohio, pick-up only.
DZL JIM
North East Ohio
Bump.
The '95 10.25 dually axle has 4:10 gears, $100.
How about $400 for the pair of Super Duty F-250 axles. Not sure on ratio, have not pulled diff cover.
PDT1081
Bowling Green, OH
Bump.
Are the tags still on the axles? You should be able to get the gear ratios from them.
