gnxtc2
Ever since I put the motor back in on Jan 2014, I get a baby romp when the motor gets to operating temp. I pulled the motor to do replace the oil pan. Since I had the motor out, I did the engine mods in my sig.
When I had the oil pan off, I checked the oil pick up tube for cracks; there were none and I left it alone.
When I first start the motor, it runs smooth and purrs. When it comes up to operating temp, then it has a baby romp. The rpms are solid. Pull power, no smoke, starts right up, no codes.
I've replaced CPS, IPR, ICP sensor, injector o-rings. I tried different tuners (DynoProven, DP and TW), all have the same romp at operating temp.
Also this happens occasionally, when I put the trans in park, the idle gets stuck at 710-750 for 30 sec then it comes back down to 650.
Here is a video that I took of the ICP and DC. You can hear the idle in the video. This is on DynoProven tunes. IMHO, the ICP jumps all over. What can cause this?
There approximately 1500 miles on Rotella 15-40. Used Rotella since day one. Approximately 15k on the HPOP and injectors. Could the HB Jr be sheering the Rotella? I have some Delo sitting in my shop.
https://youtu.be/2S_2UBSFYaY
Billy T.
[email protected]
Billy T.
[email protected]
