Hey guys going to be buying some gauges here soon is0-60psi gonna to bee good enough for 400-450hp with a 38r or s366? Or do I need more? Also where do u plumb it in?
If you think you will be running 40-45psi boost then a 60psi will be fine. If you think you will be running 55-60 psi boost then the 100psi will be better. This is a general rule I tell people.
Best place for an electric EBP gauge sensor is below...
