Bad MAF Sensor?
Powerstroke Man 6.4
So whats the symptoms of a bad MAF sensor? I pulled up the MAF sensor PID up on the dashdaq and I watched it.
I did a few half throttle + runs and with 25+ psi of boost I was seeing a max of 37.9 lb/min.
KOEO = 0.10 lb/min
KOER Idle = 4.20-4.40 lb/min
Truck has Billet S366 No limit CAI GH tunes etc.
Normal readings or is the sensor bad?
TIA
Powerstroke Man 6.4
KOEO = 0.10 lb/min
TIA
Also if it is bad will a 6.0 MAF sensor work? just for testing purposes?
madman1234509
mayfield, ny
Not totally sure. Also depends on if the tuning shuts it off or not. When my maf went bad it would throw a code. Didn't seem to run much different though, may be a little smokier then normal
