prototypemo
- Joined
- Oct 4, 2014
- Messages
- 85
- Reaction score
- 0
Will a failing Barometer cause a truck to stall out? ICP is new and in proper range, ficm volts good, ipr is new and showing good. Also its only been acting up when its in the negative temps. Split a cac boot recently so replaced it and drove fine for 2 days until it got into the negatives again the things started acting up again. had the same symptoms prior but turned out to be the a gasket in the blue spring mod that went bad, should i check that again? is that a common issue? need some assistance gents. and fuel filters are only like 6000 old...ive got code p0069, only code showing. also ebp line and map lines have been recently cleaned.....if you are wondering :cursing:
