bad moose
Was comming back from 150 mile trip. Pulled in to drop a buddy off and noticed batt light on. Kicked the Edge over to batt voltage and it was at 10.7 volts at the time. Made it home and voltage was down to 10 volts.
Well chit, altenator went bad. Put batts on charger, yanked off alt and took back to Oreilly's (lifetime warr) They tested and it tested good 14.6 volts all three times. Well chit again. Check voltage on wire going to alt 12 volts (batt charger still on) Put alt back on fired up truck 12.8 volts at alt and batteries. Charger disconnected same voltage.
Going to check charging voltage tommorrow. Any thoughts?
