Battery
henry_n5
Koeo batteries are at 12.2 and 12.4 is it time to replace them. In michigan temps about 35?
ToMang07
Mainah!
Are you having starting problems?
How old are they? Only real way to test them is load-test them.
henry_n5
There about 2 yrs old battery light came on. P0620 code trying to determine if it's batteries or alternator.
henry_n5
I have a dashdag. It reads 14.5 when warmed up. Checked at the batteries with a meter reading 14.7
Exbomber
You need a battery load tester. A meter tells you nothing when it comes to battery condition. You can have 12 volts, but no amperage carrying capacity.
The load tester applies a load to the battery, by heating a coil and you can watch the needle drop on the tester. This is the only sure way to test a battery.
Ps: when load testing the batteries, make sure you remove the cables first so you are checking only one battery at a time.
If only one battery is bad/weak, ALWAYS replace them as a set. The one that is now ok will surely fail in the near future.
If you want to know if your alt is charging, put the meter on the battery when it is running. You should see between 13 and 15 volts. If lower than 13 your alt is not charging. Above 15 your alt is overcharging.
I assume you cleaned/checked your battery connections?
rray37375
Sewanee, TN
You may be about due. Replace as a set of two. O'Reillys sells Motorcraft OEM with a 100 month warranty. They replaced two on my old 6.0, no charge and free install.
