Best place to take oil pressure
Smokin 6.0
Indiana
I'm going to hook up a oil pressure gauge to my 02 and was wondering where the best place to take oil pressure is ?
Vader's Fury
Chesapeake City, MD
Depends where you want to check pressure.
There is a plug on the block on the driver side front of the block below the oil cooler that will work. It is the same place the GEN3 attaches its feed line.
There is also a port on the filter base that can be used.
Or you can tap into the top of the HPOP res and get it from there. That is where the Dummy gauge on the dash reads from.
pdumont01
CT
Top of HP reservoir pull plug insert gauge
pdumont01
CT
I think the easiest is the HP reservoir. Its right up top and won't make any mess.
DEEZUZ
NO PUKESTERS
NWI
But isn't the lowest pressure seen at the turbo pedestal?
Pressure Gauges need to read 2 things, highest and lowest, I'd want to be reading the lowest when it comes to oil psi
