Bobs 7.3
Whats the best waterpump for an 02 7.3? Is Clays oem or china?
The only problem with the one with the built in filter is that you have to pay for it every time. Which if each one lasts 100k idk how many people will change but i'd rather have the remote coolant filter
Yeah but when the bearings in that one go out you have to buy another one and they are more expensive per pump, if you buy the remote coolant filter you can just buy regular oem pumps after that.
Unfortunately, most parts are from different countries these days. clay sells ford parts so its fords fault really..Just got one from Riff Raff and it was from China.
Mines spot clean as its 3 weeks old and can see it coming right threw the pump body. You might get lucky with a new ford o-ring for the lower inlet. Save some headache and if yours is rusty just get a new inlet too as I cleaned and painted mine and it still leaked with a new ford o-ring so had to get a new inlet too.Got to work this morning and noticed there is a puddle. Looks like its coming from the lower elbow gasket.
