big trailer for f-450
Black Beaut 7.3
Pensacola FL
Heyy fellas,
Whats the biggest size trailer I would be able to tow legally with a 1995 f-450. The truck gvw is 15k. Thanks fellas.:ford:
Bobby@cp
Wrong section bud, not only because this is the sd section but you prolly want either the obs section or tow section.
TrailerHauler
Michigan
As big as you want, as long as you don't exceed your axle weight ratings. You can pull up to a 53' gooseneck (8' neck + 45' of deck) if you wanted or needed to.
