Cutting-Edge Diesel
ok on my 05 the blinkers work just fine when the engine is cold but when it gets up to operating temp the blinkers stop working, no light on the dash or anything, any ideas?
Isn't the relay for the t/s in the under hood box? I would also check your fuses in that box too. Have seen them before when they where blown, but would make contact when cold. A test light will be your friend when its hot to trace them.
Sent from my DROIDX using Tapatalk
Blinker relay is under the dash.
yep knew that didnt want to get that far into it with out checking here first. Didnt think the fuse would be the problem since it works sometimes...
