brass in my oil
spence_08
2003 6. 0 oil is full of brass way more than any bearing in the bottom end could produce is all this from the hpop??
webb06
Seneca, MO
Main or camshaft bearings? I'm really not sure if the hpop contains brass but it might
spence_08
no its this i found my answer that pic is someone elses pic of what happend to thier pump my brass peice has let go inside mine going to pull it apart tonight to confirm
spence_08
Why do you automatically assume that's your problem with no proof?
i am 99.5 percent sure bud and ill have my proof soon as i get off work the top cover is already off the pump just have to unbolt it and take the end off it then ill be 100 percent sure and you can take your terrible attitude and stick it where the sun dont shine if you havent seen anything like this before why would you reply
BlueWaffle
Grapevine, TX
what attitude did he have? don't be a rubber penis when people are trying to help you figure out what your problem is.
HOOV3R
Central PA
Why do you have to be a dick when people are trying to help? If it's from the hpop, your hpop would be making a loud chattering noise, and HPO psi would be bouncing erratically. Also, if it's your hpop, your injectors will probably be ***ked.
ghohouston
Lewisville,Texas
I see you and your 6.0 are menstruating at the same time. Want some chocolate?
spence_08
sorry forgot to mention yah its making some bad noises and i already asumed that the injectors are finished too along with the oil cooler
HOOV3R
Central PA
Just a little advice, don't be a dick to everyone that's trying to help. It will not get you very far around here.
Extended Power
If you have that much brass in your oil/filter...it doesn't matter...you gonna be pullin the engine out anyways.
Then you can take it apart and find out what sh!t the bed.
You will find brass pieces in everything....I mean EVERYTHING!! (Speaking from experience...)
spence_08
100 percent sure its the oil pump took it off can barely turn it by and and. I took the end off it and the brass is all chewed up inside it motor is comming out to be washed and have new seals. And gaskets in it. Sucks cause I just did the heads In it a few weeks ago and put new arp studs and oem gakets
spence_08
Its called if your a dick to me ill be a dick back. Eff this site. Blows any ways ill go back to the other one where the real helpful people are. That keep their bull sh it opions to their selves. Just like the old sayings. If you don't have anything nice to say shut up. And you get what you give right so call me a dick. Idk
DEEZUZ
NO PUKESTERS
NWI
Lmao. Maybe your ****ty attitude is just like your ****ty work that trashed the motor when you had it apart.. Lmaoaoaoaoa
