Broken hose barb
eng53ine
Ohio
We put stand pipes and dummy plugs in my dad's 05 today. He broke a barb off the radiator can it be fixed or is a new radiator needed?
02 F-250, ccsb, auto, 6637, 4" turbo back, riff raff billet wheel, canned ts
eng53ine
Ohio
I've seen guys get barbed brass fittings and screw em in with some sealant.
Ok that's what we was hoping thanks for the reply
equalizier
I agree I grind it flat and run a 1/4" barb in with some black rtv sealant and has always worked.But I will say don't over tighten though you only get one shot.
78f100
Bonifay FL
If you are careful you can tap the hole with a npt tap and screw a fitting in with sealant on it. It's thin so don't tighten it too much or it will strip.
Matt_P
Lima, OH
If that doesnt work you can take it to a radiator shop as well and have a new end tank installed
eng53ine
Ohio
Ok thanks for the replies guys
