Built 2004 f-350
william_ace
Located in San Antonio, TX. No Rust!
Up for sale is my 2004 F-350 4x4 6 liter powerstroke diesel ZF6 6-speed manual transmission. The truck has 230,000 and is in great condition. I bought the truck with 221,000 miles and all work has been done since then. Truck is studded and deleted with many performance parts. I have done a ton of work to this truck since I bought it. Most, if not all of the work was done by Flyin' Diesel Performance out of Kerrville, TX. He pretty much knows the truck inside and out and would be able to vouch for all of the work done. The truck was dyno tuned at Truck Source Diesel and put down 610 hp and 997 ft. lbs. tq. I have a clean, clear title in hand.
$20,000
2004 F-350 zf6 with 230,000 miles.
Gray cloth interior
8/10 - All seats and carpets clean. No rips or tears.
Exterior 8/10 - A few very small dents and scratches. It's what I would consider normal wear and tear for a 2004.
Pro-Comp 5" suspension lift w/ 35x12.5x20 Toyo MT and XD wheels
Paint to match 2005 - 2007 front end
2008 & up paint to match rear bumper, tail lights, tailgate and 3rd brake light
New drivers side seat pad.
Arp head studs w/ OEM headgaskets and all updates 02/2013 completed @ 222k
New OEM oil cooler
Updated stand pipes
Southbend dual disk clutch rated for 650hp
Windrunner Performance Engineering regulated return
Windrunner Performance Engineering upgraded up pipes
Windrunner Performance Engineering Fully ported and EGR deleted intake manifold- (race manifold)
205/100 injectors built by Holders Diesel
Barder stage 3 68mm turbo
Full Fuel System - Fuel Lab
NEW DC powers 190 amp alternator
MBRP 4" turbo back exhaust
Batteries replaced with Motorcraft OEM
new tint all the way around
new front pads and rotors @229k
new rear pads and rotors @226k
Rotella T6 used with OEM oil filters every 3k
I'm sure there are a bunch of other things I am forgetting. I don't need to sell the truck, I just may be ready for something new. Text me for any additional questions or concerns or for more pics. I can get anything you would like to see. 210.3 eight 6 57zero8
Thank you,
Will
