Buzzing when right turning is on
Jomax
Arizona
Truck is a 1999 F-250
Buzzing comes from the blue relay behind the radio when the right turn signal is on.
I changed the blue relay, no change.
I then changed the turn signal/wiper brain(forgot the name inside the steering column).
Still no change. What else could it be????
try adding a ground maybe?
Jomax
Arizona
Well, feel like a retard. Rear bulb was burnt out. Put it in and it works.
Never had a ad rear bulb do this.
